portmap: server localhost not responding, timed out
After booting, I find the following in my dmesg:
RPC: failed to contact portmap (errno -5).
lockd_up: makesock failed, error=-5
lockd_up: no pid, 2 users??
ifconfig says lo is up:
# ifconfig lo
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:609 errors:0 dropped:0 overruns:0 frame:0
TX packets:609 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:44308 (43.2 Kb) TX bytes:44308 (43.2 Kb)
localhost is configured in my /etc/hosts file:
# cat /etc/hosts
127.0.0.1 localhost
And my routing table looks right to me:
# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
127.0.0.0 localhost 255.0.0.0 UG 0 0 0 lo
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
My only symptoms seems to be that mounting my NFS mounts at bootup takes a couple of minutes, but they still mount, and they sometimes fail to unmount at shutdown.
