I searched for this and found it, sorry for bringing up a old topic. Can someone explain a little more about installin Synaptic? I can't figure it out. I'm new to this system.
Printable View
it is use to optimize the source code for your computers. for example you might be running a pent1, pent 2 , AMD or AMD64. i386 , etc usually the ./configure script looks to see what type your are running as well as if your running linux,freebsd or another flavor of *NIX.Quote:
Originally Posted by wasserx
what is the command ./configure
its also a good idea to add a prefix to ./configure like this
./configure --prefix=/pathyou/choice
i do that so i have all non distro appzs in one place so its easier to remove. If you dont do that then you will have no idea wheter the package is part of your distro or isnt. Because alot of source code likes to install it in PATHs that your distro does.
i then add a $PATH to the new directory after i choice a prefix directory.
You may enable the firewall you will be able to download
You may enable the firewall that it what its not opening.trying to disable the firewall than you will be able to download
I hagn't been payin atenshun but:Quote:
Originally Posted by allmywebsite1
# dpkg -i *.deb
or
# bash *.run
or
# apt-get install <package name>
or
He was a spammer: he was simply copying parts of previous posts (in this case, from the first post in the thread), and the link in his signature was to some crap site.Quote:
Originally Posted by lugoteehalt
Which is why he's now banned, and all of his posts are deleted. :)
Hi friends also I want how to play song and software for which.
Can I install work software at home if instructed to do so by my supervisor? install software in violation of our company's license agreements and I simply don't is contacted by us about software piracy, that company should know we have.
Thanks to this wonderful forum, I am at the wordpress install screen First time I got that far. So I guess I don't have mysql problems after all. I will post if I have further problems. Will wait til then to mark this "solved."
John
