Installation Problem: Checking for gcc ..... no
Results 1 to 3 of 3
Thread: Installation Problem: Checking for gcc ..... no
    Dec 2003
    6
    Hi,
    I am a newbie in Linux. Please help.
    I use RedHat 9.0. I tried to install Nessus but I have the following problem during the compilation:
    [root@pclinux download]# cd nessus-libraries
    [root@pclinux nessus-libraries]# ./configure
    creating cache ./config.cache
    checking for gcc... no
    checking for cc... no
    configure: error: no acceptable cc found in $PATH
    I tried to rpm the following packages again:
    compat-gcc-7.3-2.96.118.i386.rpm
    compat-gcc-c++-7.3-2.96.118.i386.rpm
    libgcc-3.2.2-5.i386.rpm
    However it indicated that all packages have already installed.
    Please help.
    Thanks and best regards
    seekhosting
    Dec 2003
    6
    Problem Solved
    Hi,
    I searched once again for this topic in this forum. I finally got the answer from a post. The solution is install ALL Development Tools:
    To install the compilers, etc.
    Click on the redhat in the bottom left corner.
    Click 'System Settings'
    Click 'Add/Remove Applications'
    Enter Root password.
    Scroll down to "Developement"
    Install all Developement packages.
    Best regards
    seekhosting
    39,320
    Re: Problem Solved
    Glad to see you found the solution by searching the JL forums as it's a common problem here.
    Hence the reason for my 'Search First - Ask Second' quote in my signature.
We have made updates to our Privacy Policy to reflect the implementation of the General Data Protection Regulation.
