Partitioning Question - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 51 of 51
Thread: Partitioning Question
  1. #46
    Aug 2011
    4
    I think I'm totally misunderstood here --
    I DO NOT have Linux installed on USB drive. As mentioned in the first post itself:
    Here is my config, sda and sdb both are SATA drives. Windows XP is installed on sda and Linux on sdb
    sdb has the following partitions:
    sda1 -- NTFS ~920GB
    sdb2 -- linux-swap 4 GB
    sdb3 -- fat32 6 GB
    sdb4 -- ext4 70GB
  2. #47
    Newcastle upon Tyne
    2,976
    May be we misunderstood you as inside an external drive the hard disk is likely 99% a Sata disk.
    What you mean now is both your sda and sdb are "Internal" hard disks.
    My explanation still stands. You think NTLDR will obey you, via boot.ini, and boots the Linux in disk (1) when Xp has been installed in Disk (0).
    My experience is MS Windows boot loaders do have a problem booting a disk other than the one its boot loader has been residing. I can confirm having met such refusal before but I did not investigate it further or thoroughly.
    What should be understood is the Xp's boot loader NTLDR was written mainly for MS systems. While it can be used to chainload a Linux the facility is never intended to work in every situation and combination.
  3. #48
    Aug 2011
    4
    Thanks saikee
    Probably I should have clarified that sda and sdb both are "internal" SATA drives
    Again, I haven't tried this with SATA drives or XP before. However, I've done it without any issues with Windows 2000 and early versions of Fedora (5, 6) and with internal PATA drives, with windows on one drive and Fedora on the other.
    I'd like to try creating a partition fro linux on sda, just to confirm our finding
  4. #49
    Newcastle upon Tyne
    2,976
    If you were able to do it with Pata internal disks then you should be able to repeat the same for the Sata disk, especially MS Systems make no distinction between the two.
    MS Windows boot loaders can be erratic in behaviour if used outside its original intention. Although Win2k and Xp share the same name for the boot loader the code is slightly different in the two. Win2k is known to have a problem of booting Xp but not the other way round.
    I have tried using Vista's bootmgr to boot 150 Linux. It worked but failed on distros installed on disks other than the one where Vista residing. I recorded it here.
  5. #50
    Aug 2012
    7
    I used the Ubuntu text installer and went ahead and used the guided partitioner, it froze after partitioning about 17Gb, i can't find it in GParted or the Windows 7.
  6. #51
    Newcastle upon Tyne
    2,976
    CALLEIGH,
    The best way for others to advise you on partitions is to show the geometry of your hard disks by posting the output of the terminal command (in Ubuntu)
    sudo fdisk -l
    When partitioning a hard disk all the work is playing with 4x16 bytes in the partition table. Normally there is no possibility of a freeze up. May be you means formatting.
