Hey kmj, did the CD I sent you ever arrive?
Oh hey, yeah thanks! I got it a couple of weeks ago. I just got Roadrunner installed at home about an hour ago, so I'll hopefully be able to try it out.
no problem.
Originally posted by TheLinuxDuck:
<STRONG> I didn't realize that C++ had vectors.. I guess it reasons to be. I just don't know enough about c++.. maybe from now on I should keep my mouth shut.. (^=</STRONG>
http://www.codeexamples.org/cgi-bin/...vecexample.cpp
hey TLD:
there's this great site that has code examples. it's called codeexamples.org and it's run by kmj and TheLinuxDu... oops wait.
binaryDigit: Are you the same BinaryDigit from Arstechnica? (the one I called a troll just a few days back? )
Jeremy
LOL!! Actually, after I posted the original "I didn't know" message, I went to CCAE and looked, and found that example. It, of course, uses two things I have no clue about.. and they are templates and vectors. In java, sure, I know how to use a vector (and have a good idea on interfacing, which I think would be the comparible item to templates).
C++ took everything I loved about C and changed it. Maybe that's why I have such a hard time with it.. (^=
Either that or I'm just dense. I'm densing the night away... densing on the ceiling... do a little dense.. ball room densing..
That kind of thing.
Ephesians 2:8-9
Man, that was the best laugh I've had in days! TLD - hate to break it to you (and interrupt your densing) but interfaces in Java are more like pure abstract base classes in C++. Templates are an entirely different animal. An interface (or pure abstract base class) defines functions that derived classes (or implementing classes) MUST define. A template, on the other hand, is a class or function that operates on ANY object (or set of objects) which define a certain set of functionality (certain operators, etc.) Because of the way templates work, I don't think there is (or even can be) anything analogous in Java (but I could be wrong! )
"I'm not closed-minded, you're just wrong" - Bucky Katt
