I really need help this time because I can't bootup my laptop (fails even in rescue mode!). When I boot up to my old kernel 2.2.14 and my new kernel 2.4.9, I get:
INIT: cannot execute "/etc/rc.d/rc.sysinit"
INIT: cannot execute "/sbin/mingetty" (About 10 more lines of this)
INIT: Id "1" respawning too fast: disabled for 5 minutes
INIT: Id "2" respawning too fast: disabled for 5 minutes
/* again getting the same mingetty errors about 10 times more */
INIT: Id "3" respawning too fast: disabled for 5 minutes
INIT: Id "6" respawning too fast: disabled for 5 minutes
When I do a CTRL-ALT-DEL, I get "INIT: cannot execute /etc/rc.d/rc". From my experience, I only know something went wrong with the initscript but I cannot even go to rescue mode ...
I think that mingetty is the programs that make the virtual terminals. Did you hack rc.sysinit? I use Redhat 7.2 and mine is a script. Back up /etc/rc.d/rc.sysinit by naming it to something else and copy my script and see if it will work for you.
#!/bin/bash
# /etc/rc.sysinit - run once at boot time
# Taken in part from Miquel van Smoorenburg's bcheckrc.
# Rerun ourselves through initlog
if [ -z "$IN_INITLOG" ]; then
[ -f /sbin/initlog ] && exec /sbin/initlog $INITLOG_ARGS -r /etc/rc.sysinit
# If we're using devfs, start devfsd now - we need the old device names
[ -e /dev/.devfsd -a -x /sbin/devfsd ] && /sbin/devfsd /dev
# Set the path
PATH=/bin:/sbin:/usr/bin:/usr/sbin
export PATH
HOSTNAME=`/bin/hostname`
# Read in config data.
if [ -f /etc/sysconfig/network ]; then
. /etc/sysconfig/network
NETWORKING=no
if [ -z "$HOSTNAME" -o "$HOSTNAME" = "(none)" ]; then
HOSTNAME=localhost
# Source functions
. /etc/init.d/functions
# Print a banner. ;)
echo -en $"\t\t\tWelcome to "
[ "$BOOTUP" != "serial" ] && echo -en $"\\033[1;31m"
echo -en $"Red Hat"
[ "$BOOTUP" != "serial" ] && echo -en $"\\033[0;39m"
echo $" Linux"
if [ "$PROMPT" != "no" ]; then
echo -en $"\t\tPress 'I' to enter interactive startup."
echo
sleep 1
# Fix console loglevel
/bin/dmesg -n $LOGLEVEL
# Mount /proc (done here so volume labels can work with fsck)
action $"Mounting proc filesystem: " mount -n -t proc /proc /proc
# Unmount the initrd, if necessary
if grep -q /initrd /proc/mounts && ! grep -q /initrd/loopfs /proc/mounts ; then
action $"Unmounting initrd: " umount /initrd
/sbin/blockdev --flushbufs /dev/ram0 >/dev/null 2>&1
# Configure kernel parameters
action $"Configuring kernel parameters: " sysctl -e -p /etc/sysctl.conf
# Set the system clock.
ARC=0
SRM=0
UTC=0
if [ -f /etc/sysconfig/clock ]; then
. /etc/sysconfig/clock
# convert old style clock config to new values
if [ "${CLOCKMODE}" = "GMT" ]; then
UTC=true
elif [ "${CLOCKMODE}" = "ARC" ]; then
ARC=true
CLOCKDEF=""
CLOCKFLAGS="$CLOCKFLAGS --hctosys"
case "$UTC" in
yes|true)
CLOCKFLAGS="$CLOCKFLAGS --utc";
CLOCKDEF="$CLOCKDEF (utc)";
no|false)
CLOCKFLAGS="$CLOCKFLAGS --localtime";
CLOCKDEF="$CLOCKDEF (localtime
There is a bug in the bbs code and the wink emoticon is actually a semicolon and right parentheses. I'll attach a txt file in next post
Originally posted by fancypiper Did you hack rc.sysinit?
No
I have save your attachment in floppy but I don't know why I
cannot mount it in rescue mode. (I have mounted it but when
I went to the folder, nothing is there!)
Originally posted by fancypiper After you chroot /mnt/linux, try cd /mnt/linux and ls -a, can you see your root directory?
No, I can't chroot (see my posting above).
But yes, I can see etc, proc, mnt and all those stuff.
When I mount the same way for floppy, I can't see any files.
Floppy. I can mount my floppy (as root) with:
mount -t auto /dev/fd0 /mnt/floppy
Again, make sure that the directory /mnt/floppy exists and is empty. Also, /mnt/floppy/ cannot be your current directory.
After a successful mount, the files from the floppy appear in the directory /mnt/floppy/ . All the users will be able to read the files, but only root will be able to modify/delete the files. Please read further if you wanted the users to be able to write to the floppy.
To unmount a floppy (you *must* do this before ejecting the disk!) use:
umount /mnt/floppy
If you cannot unmount because "the device is busy", perhaps the /mnt/floppy/ directory is your current directory. Exit it by typing (for example):
cd
I am crossing my fingers, now let me proof read..
