tcsetattr() in termios not working correctly
basically, here is what im using to initialize a serial port to 9600 baud, and 8 N 1.
int fd;
struct termios options;
fd=open("/dev/ttyS0", O_RDWR | O_NOCTTY | O_NDELAY);
if (fd==-1)
return (-1);
fcntl(fd, F_SETFL, 0);
tcgetattr(fd,&options);
options.c_ispeed=9600;
options.c_ospeed=9600;
printf("speed = %i bps \n",(int)options.c_ispeed);
options.c_cflag |= (CLOCAL | CREAD);
options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
options.c_cflag &= ~CSTOPB;
options.c_cflag |= CS8;
options.c_cc[VMIN] = 0;
options.c_cc[VTIME] =10;
tcsetattr(fd,TCSANOW,&options);
while this program runs i do a stty -F /dev/ttyS0 and here is what i get:
speed 0 baud; line = 0;
min = 0; time = 10;
ignbrk -brkint -icrnl -imaxbel
-opost -onlcr
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
(and of course no data flow on the port)
notice the 'speed 0 baud', i know this serial port functions correctly as i've used minicom on it many times, perhaps someone can shed some light on this little dilemma for me.
thnxs
"Did you ever notice how fast Windows runs? Neither did I."
You might not use these same flags, but here's how to setup serial termios from serial programming how-to
termios oldtio, newtio;
tcgetattr(sfd, &oldtio);
bzero(&newtio, sizeof(newtio));
newtio.c_cflag = B9600 | CS8 | CLOCAL | CREAD;
CREAD;
newtio.c_iflag = IGNPAR | ICRNL;
newtio.c_oflag = 0;
newtio.c_lflag = 0;//ICANON; //0;
newtio.c_cc[VINTR] = 0; /* Ctrl-c */
newtio.c_cc[VQUIT] = 0; /* Ctrl-\ */
newtio.c_cc[VERASE] = 0; /* del */
newtio.c_cc[VKILL] = 0; /* @ */
newtio.c_cc[VEOF] = 4; /* Ctrl-d */
newtio.c_cc[VTIME] = 0; /* inter-character timer unused */
newtio.c_cc[VMIN] = 1; /* blocking read until 1 character arrives */
newtio.c_cc[VSWTC] = 0; /* '\0' */
newtio.c_cc[VSTART] = 0; /* Ctrl-q */
newtio.c_cc[VSTOP] = 0; /* Ctrl-s */
newtio.c_cc[VSUSP] = 0; /* Ctrl-z */
newtio.c_cc[VEOL] = 0; /* '\0' */
newtio.c_cc[VREPRINT] = 0; /* Ctrl-r */
newtio.c_cc[VDISCARD] = 0; /* Ctrl-u */
newtio.c_cc[VWERASE] = 0; /* Ctrl-w */
newtio.c_cc[VLNEXT] = 0; /* Ctrl-v */
newtio.c_cc[VEOL2] = 0; /* '\0' */
tcflush(sfd, TCIFLUSH);
tcsetattr(sfd, TCSANOW, &newtio);
if (i_forgot && this_is_about_code)
language = c++;
Re: tcsetattr() in termios not working correctly
thnxs
add B9600 to c_cflag, should fix it.
language = c++;
works great!!!!
THANKS !!!!!!!!!!!!
CREAD;
newtio.c_oflag = 0;
Yes... you are right... even 20 years later, adding the baud rate to the c_cflag works for me:
options.c_cflag = B921600 | CS8 | CLOCAL | CREAD; // 8N1 mode
