how to print a matched pattern
in perl, I open a file
the file has entries like 0:00:01.992 0:00:00.630 5080 2045 2468 8 81 2 1368.
I'm able to match the patern I'm interested in, which is the first set of numbers with /[0-9][0-9]:[0-9][0-9].[0-9][0-9][0-9]/
but I can't figure out how to print the matched patern, and not the whole line. can anyone give me a hand?
Re: how to print a matched pattern
well - i'm a perl virgin, but if i remember correctly, isn't it something like.
"s/^\([0-9][0-9]:[0-9][0-9].[0-9][0-9][0-9]\).*$/\1/g"
not sure if you have to escape the brackets in perl though, but if you suddenty end up with no matches, remove the "\" before the brackets.
cheers,
//blackrax
edit: what the regular expression does, or is meant to do, is to assign a group (in this case, your original pattern) and replace the line/string with that group... and if you want to simplify your expression, try
"s/^\([^ ]*\).*$/\1/g"
The string matching each regex within ()'s will be assigned to $n, where n indicates which set of ()'s.
if /((blah1)(blah2))/ matched a string
$1 = "blah1blah2"
$2 = "blah1"
$3 = "blah2"
/([0-9][0-9]:[0-9][0-9]\.[0-9][0-9][0-9])/;
print "$1\n";
OR
/([0-9][0-9]):([0-9][0-9])\.([0-9][0-9][0-9])/;
print "$1:$2.$3\n";
My Machine:
Maytag SAV5905
710 rpm Stainless Steel Drum
Dual boot: Gentoo / Tide
you can store matches to a variable using () within the regex. assuming you are looping through lines of a file, using your match pattern it would look like this:
while (<FILEHANDLE>) {
if (/([0-9][0-9]:[0-9][0-9].[0-9][0-9][0-9])/) {
print $1;
but your regex looks odd, and if i'm not mistaken it wont match any strings that begin with a single digit number. for instance, your example "0:00:01.992 0:00:00.630 5080 2045 2468 8 81 2 1368." would fail because the beginning "0:" wont match the "[0-9][0-9]:" Also, "\d" can be substituted for "[0-9]", and looks much better. Also, "^" will anchor the match to the beginning of the line to avoid any false matches.
rather than point it all out i should probably refer you to "perldoc perlretut", it's an excellent tutorial.
but this should do what you need:
if (/^(\d?\d:\d\d:\d\d.\d+)/) {
print $1;
/^(\d?\d:\d\d:\d\d.\d\d\d)/ will work as well, assuming the beginning time is always displayed to the 3rd decimal place.
Roses are red, violets are blue. All my base, are belong to you.
Fantastic, thank users. I'll be able to put your tips to the test later this week. much thanks!
PS. I have several perl books(oreily) learning perl, cookbook, and for administrators, perhaps I was not looking closely enough, but I don't think that information was in there, is mastering expresions a good book to have?
