Linux for dinosaur systems
Hello,
I have a 486 with 8 mb of memory and a Pentium 200 with 32 mb of memory. I'd like to use Linux to get a GUI interface similar to what Windows 3.1 gave me. All I want to do is use OpenOffice and maybe get on the Internet. I tried Mandrake on the Pentium, but it wouldn't install. I looked at Redhat and Suse, but those said I needed more horsepower and more memory. What Linux distributions would be best for that 486 and Pentium 200?
Thanks!
Debian would work (dunno how easy it would be to install).
I really am not sure about how succsesful openoffice would be though.. You might want to look into abiord or kwrite...
irc.freenode.net #justlinux The Not So Official JL IRC Channel.
¤ Debian ¤ Apt-Get ¤
OpenOffice uses way more than 32MB of ram by itself, so running it on either of your boxes isn't likely.
I think Mandrake requires a 686 now a days, so it may not run on either of them.
Debian or Slackware are good bets.
You might want to try Gentoo, but expect a REALLY long compile time (and a 15% faster distrobution). And OOo really /should/ have 64mb of ram, or, preferably, 128mb.
MOUNT TAPE U1439 ON B3, NO RING
Registered Linux user # 31337!
Slackware!
OOo will not run smoothly on equipment that old, and definitely not on a 486.
For the Pentium 2, you should be OK with AbiWord if you add some more RAM.
If that's too slow, and for the 486, try a 1.0.x release of AbiWord, which is really ugly (no antialiasing), but faster.
Dillo for web browsing, or maybe firebird on the Pentium 2 but even that will eat a lot of resources.
Have fun
~psi42
Moving to the '.iso confused - Which Distro?' forum.
http://old.lwn.net/Distributions/ is a great resource for finding specific distros.
For a "dinosaur" system, there is a new distro out, Tyrannasaurus Rinuxx, but it is more for high performance.
I think they have a slower version, Brontosaurinux. And for mobility, laptops, etc, there is Pterodactylinus .
A waterproof distro, Plesiosaulinex, is being developed.
I guess we could call it the "Distrosaur" section.
__________________________________________________ _______________________________________
Bigboogie on boogienights.net:
Ammo case
Asus 8N32 SLI MB
AMD Athlon x2 3800+
2 GB Patriot Signature 400 DDR
160 GB Hitachi 7200 IDE
2 x-250 Seagate SATA2
EVGA Nvidia 7900GT
Dell 2007WFP
Logitech 5.1 speakers
Logitech MX1000 mouse
Dell USB keyboard
NEC 3500 DVD-RW
Benq 1655 DVD-RW
(God bless tax refunds)
are you having a giraffe?
Ped33322, go slack
If you are looking for some used hardware that will run linux well. check the hardware trading forum. I have some stuff listed in there.
Check out my ebay auction for my signature space on JLC.
Hey if people can sell advertising space on thier bodies, I figure I can make $.02 on my signature space.
No, but I was sticking my neck out.
Ammo case
Asus 8N32 SLI MB
AMD Athlon x2 3800+
EVGA Nvidia 7900GT
Dell 2007WFP
Dell USB keyboard
NEC 3500 DVD-RW
Benq 1655 DVD-RW
For an older system like that, you are probably looking at Slackware or Debian as your first options.
With regards to window managers that look like Windows 3.1, I don't think you'll find any (because most people think that 3.1 sucked). But you could look at Rox-filer, which has a WM component.
Alternatively, the *box WMs are very light on resources, or IceWM (you can get a 'nice' WinXP look for IceWM which would confuse some)
I have run OpenOffice on a machine with 24Mb RAM, windows version, but it's not pretty. Even 64 is slow.
mrBen "Carpe Aptenodytes"
Linux User #216794
My blog page
3rd year running - get yourself to LugRadio Live 7th-8th July 2007, Wolverhampton, UK. The premier FLOSS community event.
I suggest you have a look at Vector. They target older computers.
Vector's a good choice, considering it's based off of Slackware.
I had a Compaq laptop, 486/33 mhz with 8MB of RAM, and a 270MB hard drive in it. I think I managed to get a base Slackware install in at around 88MB or somewheres in there. Of course, all I used the laptop for was a remote telnet console, but it worked great!
Registered Linux user #230403! Since March 2001! YAY.
Try doing a forum search or a google search before asking a question. And please don't use HELP! in the topic of your post... it's so lame... Please don't PM me for help-- post a question in the forum instead.
I suggest one of the mini KNOPPIX-based distros - Feather Linux, Damn Small Linux or Flonix, and maybe Puppy Linux (though its hardware detection isn't great as yet).
Registered Linux User #325947
Check out Feather Linux, my distro.
(Yes, it's shameless self promotion, deal with it )
