No Sound in Debain SID
Hello Everone,
I have been trying to solve this problem for the last 2 days
I am getting no sound what so ever from my new Debian sid system, Cd's look like they are playing fine and everything but I get no sound. I get sound in both Fedora and Mandrake. I am currently running Debian SiD 2.6.6-1-386. but I have the same issues with bith MEPIS 2004 Beta 5 and knoppix 3.4 after doing HD installs
I have checked to make sure that nothing is muted that pertains to system sounds or cd's
2. I have made sure the emu10k1 module is loaded and according to both lsmod & LSPCI and modconf the driver for my card is loaded here is the output of lsmod, the parts that pertain to sound anyway
snd_pcm_oss 47652 1
snd_mixer_oss 16640 1 snd_pcm_oss
ipv6 220384 10
af_packet 20616 2
usblp 11904 0
eth1394 19464 0
uhci_hcd 27920 0
usbcore 95068 4 usblp,uhci_hcd
ohci1394 31876 0
ieee1394 100024 2 eth1394,ohci1394
emu10k1_gp 3840 0
gameport 4736 1 emu10k1_gp
emu10k1 71684 0
sound 75308 1 emu10k1
ac97_codec 16908 1 emu10k1
pci_hotplug 32176 0
via_agp 7424 1
agpgart 31272 1 via_agp
pcspkr 3816 0
tsdev 7168 0
mousedev 9684 2
psmouse 17544 0
floppy 54996 0
parport_pc 31552 0
parport 37320 1 parport_pc
evdev 9088 0
snd_emu10k1 80004 1
snd_rawmidi 22688 1 snd_emu10k1
snd_pcm 84900 2 snd_pcm_oss,snd_emu10k1
snd_timer 23044 1 snd_pcm
snd_seq_device 7944 2 snd_emu10k1,snd_rawmidi
snd_ac97_codec 54916 1 snd_emu10k1
snd_page_alloc 10884 2 snd_emu10k1,snd_pcm
snd_util_mem 4608 1 snd_emu10k1
snd_hwdep 9120 1 snd_emu10k1
snd 48356 10 snd_pcm_oss,snd_mixer_oss,snd_emu10k1,snd_rawmidi, snd_pcm,snd_timer,snd_seq_device,snd_ac97_codec,sn d_util_mem,snd_hwdep
soundcore 9824 4 emu10k1,sound,snd
what should I set is my sound system OSS?
3. I have made sure that the cdplayer was
set to my first cdrom /dev/hdc
here is my fstab
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/hdb1 / ext3 defaults,errors=remount-ro 0 1
/dev/hdb5 none swap sw 0 0
/dev/hdc /media/cdrom0 iso9660 ro,user,noauto 0 0
/dev/hdd /media/cdrom1 iso9660 ro,user,noauto 0 0
/dev/fd0
I also checked the volume control in KDE and both CD and speaker are set to mid to high levels
update - I also made sure my user is part of the auido group & I also have no sound using my root account either
any help would be awsome
Thanks
bosox
why do you have snd_emu10k1 and emu10k1 modprobed?
looks like both alsa and oss are installed, so maybe a problem there... rmmod everything and try just modprobing emu10k1...
irc.freenode.net #justlinux The Not So Official JL IRC Channel.
¤ Debian ¤ Apt-Get ¤
Thanks for the reply sharth ,
I went ahead and removed all the emu10k1 modules, but during the processoes I got this error
rmmod snd_emu10k1
ERROR: Module snd_emu10k1 is in use
so I assume this is the module that I will want to use? I probly have both modules probed becuse of kudzu I used that to try and locate the correct module for my system.
what sound system would you remove alsa or OSS? or can I just disable one and use the other? I modprobed emu10k1 I'll post back after restarts
Thanks for all the help so far
ok update I got my system sounds to work by using OSS, but I still get no sound from auido cd's in XMMS or KsCD or cdplayer
Hey Tyler... Do you have the audio cable between your cdrom and soundcard?
If that's not the case, execute xmms at the commandline to see if you get any errors. Also ensure you have the correct sound output device select for both XMMS and KsCD.
We've had *cough* lots of posts here on XMMS and 'no sound' that may provide additional suggestions.
Hopefully I've at least given you something to go on.
Personally, I'd suggest alsa since oss is getting depreciated... (but with emu10k1, support in both is fine, so i dunno.)
With xmms, thats a whole different ball game. It might be that audio cable that goes from the sound card to the cdrom drive, but other than that, I have no clue.
don't worry about libmikmod.so.2, it's pointless. Apparently, it just gives support for mod, stm, s3m, mtm, xm and it audio files.
Try playing the audio cds as root, since you need read access to the dev file for your cdrom.
sharth,
Thanks for the info, I had no idea what the error meant! I think I am going to give the Knoppix 3.4 HD install another shot. I just need to read up on the installer options to see what I want use. I'll keep everyone posted
Update I did a newbie HD install of knoppix 3.4 and all is well execpt 2 things
1. I am still unable to play auido Cd's with KSxd or XMMS both apps do'nt even see my cdrom drive or that anything is in it, so it will not even attempt to play - the sound
2. I am unable to get the KDE 3.2 startup .wav to play from my user account, but it does play when I boot into my root account,
I am able to get sound from flash movies and play MP'3 though
Ensure the user is a member of the 'audio' group and verify the devices in /etc/fstab are correct for your cdrom(s).
That's about all I can think of right now.
According to the groups tyler command these are the groups I am a memeber of already tyler dialout fax voice cdrom floppy tape sudo audio dip video games users usb
and this is my fstab
# /etc/fstab: filesystem table.
# filesystem mountpoint type options dump pass
/dev/fd0 /floppy vfat defaults,user,noauto,showexec,umask=022 0 0
usbdevfs /proc/bus/usb usbdevfs defaults 0 0
sysfs /sys sysfs defaults 0 0
/dev/dvd /dvd iso9660 defaults,ro,user,noexec,noauto 0 0
/dev/cdaudio /cdaudio iso9660 defaults,ro,user,noexec,noauto 0 0
# Added by KNOPPIX
/dev/hda1 /mnt/hda1 ntfs noauto,users,exec,ro,umask=000 0 0
# Added by KNOPPIX
/dev/hdb5 none swap defaults 0 0
I guess I'll try switch KsCD to point to /dev/dvd
Thanks for all of the help everyone
