problems installing kernel source w/ SuSE 9.1 Personal
Results 1 to 7 of 7
Thread: problems installing kernel source w/ SuSE 9.1 Personal
    Oct 2002
    Vacaville, CA
    20
    Need help -- problems installing kernel source w/ SuSE 9.1 Personal
    Not sure if this is the right forum, but....
    Has anyone had problems installing the kernel source in SuSE 9.1 Personal? I have downloaded the source rpms from the SuSE FTP site. When I click on the RPM, it opens YaST. I then click on the button that says "install with YaST." YaST then closes quickly, and I do not see a /usr/src/linux directory. The same thing happens when I try to install the gcc source. Installing from the command line yields the same results, and the packages are not listed when I do an rpm -qa. Does anyone have any tips for this, or should I just bite the bullet and use 9.1 Professional?
    Thanks.....
    Jun 2002
    Nashville, TN
    487
    Don't think the Pro version is going to help you out here. It doesn't have anything to do with that I wouldn't think. Try actually installing the rpms via the command line, ie.
    rpm -ivh kernelsources.rpm
    and see if you get some error messages. Could be that yast is just borked up.
    My Weblog
    ASUS A7N8X
    Athlon XP 2500+
    GeForce FX 5200 128Mb
    1Gb PC2700
    120Gb & 40 Gb HD
    Gentoo & Flux
    Oct 2002
    Vacaville, CA
    20
    Installing via the command line with the -ivh switch does not produce any error messages. I get the hash marks #### up to 100% then it kicks me back to the command line. Querying the rpm database shows the package is still not installed, and there is no /usr/src/linux directory.
    Jun 2002
    Nashville, TN
    487
    /usr/src/linux is normally just a link to /usr/src/linux-2.x.x
    See what you have under /usr/src. Also do a
    rpm --rebuilddb
    then try to query all and see if its there.
    My Weblog
    ASUS A7N8X
    Athlon XP 2500+
    1Gb PC2700
    120Gb & 40 Gb HD
    Gentoo & Flux
    Oct 2002
    Vacaville, CA
    20
    I'll give the rebuilddb command a try tonight. The only folder under /usr/src that I saw last night was /packages.
    Jul 2002
    Vladivostok, Russia
    9,053
    Its just as easy and more straightforward just to download the source and uncompress it to /usr/src. Why put one more equation to work with..... in the soup?
    "I was pulled over for speeding today. The officer said, "Don't you know
    the speed limit is 55 miles an hour?" And I said, "Yes, but I wasn't going
    to be out that long."
    How To Ask Questions The Smart Way
    COME VISIT ME IN RUSSIA NOW!!
    39,307
    That would indicate you have successfully installed that rpm package.
    Are you sure you are installing the correct kernel source?
    You want the one similiar to
    # rpm -qa | grep kernel-source
    kernel-source-2.4.21-215
    which would actually have the extension of i386.rpm or i686.rpm and NOT src.rpm. The src.rpm package would install the kernel source in /usr/src/packages and not /usr/src/linux-#-#-#.
    The i#86.rpm package is the resulting kernel source after compiling that particular kernel version.
    The src.rpm package is a uncompiled kernel source.
    Note: This is from SuSE 9.0.
