Audigy Problem in SuSE
Results 1 to 4 of 4
Thread: Audigy Problem in SuSE
    May 2004
    58
    Whenever I reboot SuSE 9.1, my sound card stops working. The system recognizes it, but it will not work. If I go into the Sound Card settings, delete the card and then readd it, it works fine.
    Any ideas? Sounds like a driver could be preventing the SoundCard from loading. However, I am a newbie and not exactly sure where to look from here.
    Thanks.
    May 2004
    58
    OK - part 2 to this dilema.
    Now I have rebooted, the card did not work after deleting readding. After two more reboots, I was able to do the delete/readd.
    Also one other piece of information. It works fine under XP and I have reinstalled SuSE twice trying to remedy this.
    39,320
    Have a look to see what soundcard related modules are loaded and if you are using ALSA and not OSS.
    ALSA modules start with snd- (i.e. snd-emu10k1), while OSS modules would be emu10k1.
    Did you properly setup/configure sound during installation?
    Is alsasound set to execute in the runlevel you are booting to? If runlevel 5 (full multiuser, networking & GUI desktop), you should see something like
    /etc/init.d/rc5.d/S13alsasound
    May 2004
    58
    snd-emu10k1 loads during boot. It worked fine during the Sound test during installation so, I assume it was setup correctly during installation.
    I have a file /etc/init.d/rc5.d/S12alsasound also.
    Any other ideas? It now doesn't work at all. Deleting/reinstalling doesn't work any longer.
