index out of bounds exception in fileoutputstream (java)
the following is some code im having some problems with:
// int bytesread
// InputStream imagestream
// and FileOutputStream tempstream
bytesread = imagestream.read(buffarray);
while(bytesread!=-1)
tempstream.write(buffarray,offset,bytesread);
offset+=bytesread;
im using this bit of code to read a .bmp image from a mysql db, it does fine for images under 100k but anything above 100k i get an "index out of bounds exception" thrown on the fileoutput stream. any ideas??
"Did you ever notice how fast Windows runs? Neither did I."
Which specific line is giving you problems? And, if you are getting "IndexOutOfBoundsException" I would start checking anything that involves an array -- being trying to access outside an array's length, that exception is thrown. I notice you have a "buffarray" variable. Depending on where that exception is thrown, my guess would be to start looking there.
Distribution: Gentoo
Kernel: 2.6.9-r9-gentoo
Processor: Intel Pentium 4 1.3Ghz
RAM: 256MB RAMBUS
HD Space: 300GB (60/80/160)
<beastmaster> eh yeah same here, used to use mandy lol
<beastmaster> yeah damn.. that was a waste of 2 years right there lol
the exception comes from java.io.fileoutputstream.writebytes(). buffarray is defined as byte[102400].. im not seeing how i could have a indexoutofbounds regarding this array as the iimagestream.read() procedure automatically reads to buffarray.length and returns the # of bytes read in bytesread so then i write the bytes out in tempstream.write at an offset...so from this loop at no time should bytesread > buffarray.length() where buffarray.length() = total # of elements in array....
as a test i doubled size of bytearray and it wrote the 1st 200 bytes of my file and then crapped out SO this leads me to beleive that there is a problem with the offset parameter im passing to the tempstream.write() function...im thinking the offset should be = to bytesread-1 since the offset is 0 based and bytesread is not...after i wake up fully i shall test this further...
Re: index out of bounds exception in fileoutputstream (java)
// int bytesread
offset+=bytesread;
I haven't done any Java in about 3 years, so I may have lost my Java legs.
Wouldn't read populate indices 0 through bytesread-1 of buffarray each time it is called? If that is the case, shouldn't the write offset always be 0? As I understand write it copies indices offset through offset + bytesread into the tempstream.
If these are all true, then only the first write to tempstream would write useful data, but you stated that everything works for files under 100k.
My Machine:
Maytag SAV5905
710 rpm Stainless Steel Drum
Dual boot: Gentoo / Tide
yes i just realized that!
i hate writing code when im sleepy :P
