Need help with a script
Results 1 to 6 of 6
Thread: Need help with a script
    Jul 2002
    TN
    1,009
    I know absolutely zip about programing but I need something that will listen for when a program quits and then restart it. I have a server running a scorched3d mod 24/7 and a couple of times it dropped and I need it to be restarted automatically.
    Any and All help apreciated
    thanks
    Linux reg. User # 298337
    14,947
    Hmm... quick and dirty solution:
    $!/bin/bash
    while /bin/sleep 20 ; do
        if ! ps -C processname >/dev/null 2>&1 ; then
            processname &
    done
    Change both "processname"s to be the name of the executable (use the full path on the second one, if you want). "ps -C blah" checks whether "blah" is running. If it is, it exits successfully (after printing some unused pieces of information, which we redirect to /dev/null), and if it's not, it exits with failure. The "if" checks the status of ps, and runs "processname" in the background if the ps failed. This is the restart part of the script.
    Before checking the status, it sleeps for 20 seconds. This is to prevent it from burning all the CPU cycles it can. The sleep time (20) can be adjusted based on the maximum amount of time you want to wait before restarting it, but setting the time too low will cause a lot of unneeded CPU activity.
    To kill the monitoring script, kill the corresponding sleep process. This will cause the while loop to exit, because sleep will not have exited successfully.
    Dump this into a text file, and chmod +x it. Then run it in the background, as whichever user is supposed to start your server program.
    Oct 2003
    Vancouver, BC, Canada
    215
    The easiest way to do it would probably be to write a script that grep's the output of the ps command, then restarts the program if it's not listed. There are likely better ways to do it though. Something like (this isn't real bash, but you get the idea):
    while something; do
    sleep 10
    ps aux > /tmp/progcheck       # so we don't grep our grep command
    grep -q servername /tmp/progcheck
    if $? = 1 restartserver   #grep returns 0 if pattern found, 1 if not
    done
    rm /tmp/progcheck
    edit: never mind, use bwkaz's, it's cleaner, and it works
    Adam
    Dell Inspiron 600m
    P-M 1.6 GHz | 512MB RAM | IPW2100 Wireless | CDRW/DVD-ROM | 40GB HDD
    Jan 2004
    Ukraine
    228
    #!/bin/bash
    while : ; do
    # sleep 1 # you can avoid sleep altogether
    if ! ps -C xedit >/dev/null 2>&1; then
    xedit
    done
    just some cosmetic changes. (Don't know either if it's a perfect solution.)
    Slackware + *BSD :: RLU 301327
    Earth [I think...]
    414
    How about just putting the following entry in /etc/inittab:
    program_name:2345:respawn:/path/to/program
    This will restart the program incase it dies. Check http://publib16.boulder.ibm.com/pser...es/inittab.htm for more details on inittab.
    Hope this helps.
    - Suramya
    My Website: http://www.suramya.com
    My Blog: http://www.suramya.com/blog
    Registered Linux User #: 309391
    Disclaimer:
    Any errors in spelling, tact, or fact are transmission errors.
    Jul 2002
    TN
    1,009
    Thanks all. I'm investigating all above posts.
    This place is great.
