[SOLVED] Old home locked up
Hey guys, been awhile,
I blew up an older debian system, and I'm going to upgrade it to ubuntu. Now, I REALLY need the mail (from mozilla suite) out of this system. I currently have ubuntu on it now, with the old /home partition mounted as /backup. I belive that the old mail should be hold up in some ./mozillawhatever, but the home folder is locked, even from root. By "locked", I mean I can't open or view it.
What can I do? The old system is gone, so am I screwed?
"We are not without accomplishment. We have managed to distribute poverty equally."
-Nguyen Co Thatch, Vietnamese foreign minister
did you try using chmod? root should, in theory, be able to access/change the perms
"I wouldn't say there are no stable character attributes in a person
that contribute to moral or immoral behavior, but they are far
outweighed by where the person is, at what time, and with whom."
-Lee Ross, coauthor of "The Person and the Situation: Perspectives
of Social Psychology"
Registered Linux user number 332965
Did you remember that Ubuntu has no root when attempting to read the folder? Ubuntu doesn't have a root by default, system administration tasks are being done with your user account and the sudo command. I suggest you try
sudo ls /backup
Password: *enter user password here*
you mean, right parcival?
Yes, when the sudo command is entered, the shell prompts you next for your user password.
No problem.
YES! I have it! Thanks guys!
