N-Gage takes 3 kicks to mount
Results 1 to 6 of 6
Thread: N-Gage takes 3 kicks to mount
    Apr 2003
    Finland
    138
    I've been having problems mounting my Nokia N-Gage lately. I know I have the kernel support and udev rules down, but for some reason I have to run the mount commmand three times to get it done. Maybe not a big deal, but I really hate this kind of seemingly random operation.
    janne@Devastator ~ $ mount /mnt/n-gage/
    mount: No medium found
    mount: wrong fs type, bad option, bad superblock on /dev/ngage,
           missing codepage or other error
           In some cases useful info is found in syslog - try
           dmesg | tail  or so
    It doesn't matter how long I wait after I plug in the device, I get the same result every time. So what's wrong and how do I fix this?
    Running:
    Pentium D 3GHz Dual Core - 2GB - Ubuntu 9.04
    PIII 850MHz - 256MB - Ubuntu 8.04 Server
    Registered Linux user number 312827
    Aug 2001
    Somewhere, Texas
    9,628
    check dmesg or /ver/log/messages and see what the kernel is doing that's freaking out
    Oct 2002
    Illinois
    3,289
    no wonder it failed horribly on the market
    Apr 2003
    Finland
    138
    Mostly they just give me a load of dropped packages, but I was however able to pick a couple of lines from there which I suspect might be relevant.
    usb 4-2.1: new full speed USB device using uhci_hcd and address 29
    ub(4.29): Stall at GetMaxLUN, using 1 LUN
     uba: uba1
    FAT: bogus number of reserved sectors
    VFS: Can't find a valid FAT filesystem on dev uba.
    Any ideas?
    Running:
    Aug 2001
    Somewhere, Texas
    9,628
    maybe the vfat needs to be formated? it is FAT after all and you have had it for a while and I know you've given it more then mild use
    Nashville, TN
    3,199
    is this the memory on the NGAGE itself, or a memory card?
    you might need to consider actually re-formatting the card in a Windows machine, or something, and trying again. Just a thought...
    Registered Linux user #230403! Since March 2001! YAY.
    Try doing a forum search or a google search before asking a question. And please don't use HELP! in the topic of your post... it's so lame... Please don't PM me for help-- post a question in the forum instead.
