Complete NOOB need help
I am a complete NOOB to linux and shell scripting and need help
this is what I am trying todo
1. Create a script that takes 1 argument being a file read the inputted file, and look for occurrences of the current user who is executing the script. On finding an occurrence of the username take that line and append it to a file and display a line number and a bracket against the saved line.
my efforts sofar
#!/bin/bash
echo "filename"
read myvar
grep $USER $myvar > results.txt
nl results.txt
2. Write a script that takes two arguments. The first being a line of text, the second being your newly created file. The script should take the first argument and insert it into the middle (middle line) of the file named in second argument.
Thanks in advance for any help
Hi,
Have a read of the Posting Guidelines.
This isn't home work is it
Have a look at The Linux Documentation Project:
TLDP : Guides
Bash Guide for Beginners
Advanced Bash-scripting Guide
To see if they can help you at all.
Your very close to having the first one working properly, '>' redirects and overwrites a file, as you've found out. Have a look through the bash guides, or a google for 'bash file redirection'
One thing you might think about doing:
read your results file, and loop through each line, formatting the output the way you want and redirecting it to another file.
thanks for the reply ... and NO it's not homework ...
Had to ask, the number of homework questions is quiet large at times, and to be fair it sounds like one
I don't think you can format the output of nl the way you want. A while statement is possibly your best way to go...
count = 1
while read line from results.txt do
print $count) $line > anotherfile.txt
count++
done
mv anotherfile.txt results.txt
This should do close to what you need it to for the first part:
sed "s/$USER/[&]/g" $myvar | grep $USER | nl >results.txt
well, the way you ask the questions, it is 99.99% homework to me..but nevertheless there's still 0.01% benefit of the doubt i can give to you.
USER=$1 #first argument
awk '/'"$USER"'/{print NR " " $0 > "results" }' "file"
it says take the input "file", match the user and bring the record number, and that matched line into "results" file.
if your file is not very large..this is one way..
awk -v text="$1" -v file="$2" '{arr[++c]=$0}
END{
for(i=1;i<=c/2;i++){
print arr[i] > file
print text > file
for(i=c/2+1;i<=c;i++) {
print arr[i] > file
}' "file"
Thanks guys
yep these all work.... except I cannot use AWK or SED .
and as I have said this is NOT homework .... it's an Adult education course I am doing.
Wouldn't that make it homework
Why can't you use awk and sed?
#!/bin/bash
echo "filename"
read myvar
x=1
cat results.txt | while read line
do
echo "$x) $line" >>results2.txt
x=$((x+1))
done
Should do what you need, it's not nice though, without using sed or awk.
well... its still homework in a way right? just that its not going graded maybe?
Registered Linux User #388117
At least I know you aren't one of my students... we don't start shell scripting until tonite's class
Originally Posted by deathadder
#!/bin/bash
echo "filename"
read myvar
x=1
do
x=$((x+1))
done
catting a file and piping to while loop is unnecessary because the while loop itself can take in redirection. it can be shortened to
while read line
do
done < $myvar
or just
grep $USER $myvar | while read line
why not have a look at fgrep?? That should trim it down to about 2-3 line of code
Ah thanks for letting me know that ghostdog74, my scripting is in need of improvement as you can tell
