ACPI battery automatic shutdown or auto resume when battery reachs 7%
Results 1 to 4 of 4
Thread: ACPI battery automatic shutdown or auto resume when battery reachs 7%
    Sep 2005
    681
    I have had problems with my pavillion hp laptop for a while. I have it serviced at HP two times in 3 months for the same battery issue problem. If i let my battery run out the comptuer has no way to recharge it. IT might be a bug with HP ACPI system. I was wondering if theres a way to have the linux kernel idle it or shutdown the comptuer when my battery reaches 8%.
    I want to avoid the problem of letting it run to 1% and not charging again. The reason i don't always notice it is because im doing stuff in command line alot and if i don't
    keep looing at the /proc/ACPI/*/* then i have no way to tell.
    "Software is like sex: it's better when its free."
    -LINUS TORVALDS
    Jan 2001
    517
    look at this link under heat and power:
    http://www.hep.phys.soton.ac.uk/~jhe...-zx5030EA.html
    specifically what it says about using an smp kernel
    Sep 2005
    681
    thanks, look like the scripts there do what i need. i thougth there was probably a deamon that looked at the /proc/ACPI do you know of any .
    -LINUS TORVALDS
    14,947
    I know acpid can run programs when various events happen, but I'm not sure if it can do exactly what you need. Maybe worth a look though?
