I have a laptop and a server.
the server does not have a soundcard,I want to put on it a radio server
so that it creates a stream to wich I could listen from the laptop.
can I stream from the server if it has no soundcard ?
how would I go about doing the playlist etc ?
how can I do this in a simple way ?
I've tried with icecast many times but I can't seem to get it right and the
documentation is very poor.
please help me out here,I'm in the dark
It sounds like you want to stream your own mp3, etc., to your laptop, and not listen to some internet radio station. If that is the case, read on.
The answers to your questions, in order:
1. Yes, you can stream from a machine w/o a soundcard. Soundcards are for speakers, not networks.
2. You can create your own playlists by hand, or have a program do it for you. I use Amarok to listen to music; if you do too, then just select Playlist-->Save Playlist As from the toolbar, and it will create a playlist for you.
3. I recommend gnump3d. It is a small, password-protected (if you desire) music server that will stream your music to you. It allows you to browse your music via a web browser, and includes a search.
I think this is actually asking about a network stream, but need clarification to be sure.
For streaming own mp3 files, just create a samba or nfs share and mount it on the laptop, then play the files as if they were local.
If it's a stream in real time, just tune to it via the laptop.
If it's a stream with time shifting, then it requires streamcast or mplayer to tune to and dump the stream, then it can be accessed as above. (Or for a GUI, just use Rythmbox or Amarok to tune to the stream and then share the folder where they are stored...
Anyway, not sure what the desired outcome is, need more details.
thanks allot.I tried gnump3d before I started this thread,it did not work,but now I insisted a little bit and with your indications and I also found this
useful http://www.linuxtopia.org/online_boo...e/ch07s07.html
I got gnump3d working,now I can listen to music wich is not stored on my
computer,that was my main goal.
@psych-major
as samba is used to bridge windows to linux it's an un-natural solution.
EDIT:
I have one more proble,altough I forwarded 8888 on wich gnump3d works
on my router gnump3 still is not accessible from outside my LAN.
what should I do about this ?
@quip
how do I make a stream like all the radios have ?
this stream seems to make the playlist inside the m3u wich is not
very convenient... and not a real radio...
When i first got into perl i found a mp3server script over at perlmonks.org
it was nice and simple, but didnt have stuff i wanted, so i started adding my own features, such as custom playlists, and a better random file selector.
alas i never uploaded it to the internet, but still have a copy on my computer
now i re-found the link for the original mp3server but, as im 800 miles from my computer at my wife's family for christmas, i dont have a copy i can upload right now.
if you're paitence enough i'll be home on the 3rd or4th and i can upload a copy if you wish
yeah that's very nice and I'll take some time soon to read the
script as I find this a very nice use for perl.
as for your additions to the script I am patient for you to upload
them,meanwhile using a compromise(because I don't know how
to properly set it up...slimserver
@quip
Really can't say. I would say you probably need to make sure 8888 is the one gnump3d is using. If it is, and your router is properly configured, and your music player has the correct address (with :8888 on the end), then I would try another port.
As far as the stream: gnump3d is not set up to do that easily, I believe. You can log into it and select "random" or make a custom playlist, but anyone you want to let listen to the music will need the addy/password. I assumed you wanted it just for yourself.
One modified Perl MP3 Server as promised albit a tad late. ( sorry internet was down )
::EDIT::
uggh forgot to tell you how to use it
its not that much different from the original although i added some functionality
1) run the mp3 server
2) connect with your favorite MuiscApp (winamp,xmms,WinMedPlyr, whatever)
use this url to connect
{server}:{port}/{opt1=val1+opt2=val2}
where options are
plist: name of playlist file you want minus the '.pls' (just a simple list of mp3 filenames separated by newlines)
skip: skip value for the randomness (nice prime numbers are best) default 83
start: index of song you wish to start with eg 0,1,2....
so example url would be
127.0.0.1:1942/plist=rock+skip=11+start=12
this would connect and load rock.pls with a skip of 11 starting with song 12
other thing in the actual source code near the top (lines 14 & 16) are variables that hold the directories of the playlist and the mp3 collection
