Suddenly no sound on 64 bit mepis/debian
Results 1 to 11 of 11
Thread: Suddenly no sound on 64 bit mepis/debian
    Aug 2002
    476
    Hi Guys,
    Something... occurred to my audio on this machine, hope you can help.
    I believe I heard the KDE fanfare when I booted up the first time after installation, but now - nothing.
    from lspci:
    00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
    I tried some of the stuff from here http://ubuntuforums.org/archive/index.php/t-940689.html Adding the boot option: kopt=irqpoll to grub
    - and the three lines:
    options snd-hda-intel model=3stack-dig
    options snd-hda-intel enable_msi=1
    options snd-hda-intel single_cmd=1
    to /etc/modprobe.d/alsa-base, but nothing.
    An assist would be much appeciated.
    Thx for reading
    Jul 2002
    Vladivostok, Russia
    9,053
    "I was pulled over for speeding today. The officer said, "Don't you know
    the speed limit is 55 miles an hour?" And I said, "Yes, but I wasn't going
    to be out that long."
    How To Ask Questions The Smart Way
    COME VISIT ME IN RUSSIA NOW!!
    Aug 2002
    476
    Thx for responding John.
    I have restarted several times while having this problem, but today, something happened.
    I went into Ubuntu on the same machine, booted down again after a while and back into Mepis and whatta ya know, sound was back! How? The volume slider in kicker doesn't work though, but when I open Kmix, the master volume slider works just fine.
    How does this happen? I don't get this, weird stuff.
    - and no, I hadn't seen that. Seems like a lot of trouble to get something as common as an Intel soundchip to work.
    Oct 2002
    Binghamton NY
    2,435
    Always check your permissions when having problems with audio, especially with Ubuntu, and I believe mepis is based on Ubuntu these days. Is your normal user a member of the "audio" group? I think I've actually lost audio during an upgrade once.with Ubuntu. I had it during the beginning of the upgrade, and then I didn't have it. It was fairly recently, and it was just this problem. I don't know how plausible it may be that this is your problem. I don't know how or why it happens, but it's always the first place I look and 90 per cent of the time, it's just that. That other ten per cent of the time, I don't have my speakers plugged in or something like that.
    Jul 2002
    Vladivostok, Russia
    9,053
    Quote Originally Posted by arioch View Post
    Soundchip configurations are not that simple from version to version(ICH9 Family) and after any upgrades to your distro there can be numerous things affected.
    Aug 2002
    476
    AFAIR, Mepis is back on the debian wagon (Lenny stable) I guess they just got sick and tired of "the Ubuntu-way" too. There's also a limit to how long I can go without KDE (3.5.10)
    Thx for the responses.
    Oct 2002
    Binghamton NY
    2,435
    For the sake of reference, this just happened to me again, with Kubuntu jaunty. I installed some software with apt-get, including xfce (xubuntu-desktop) and was prompted afterword to restart, and after I restarted, no audio. I checked kuser, and sure enough, I was no longer a member of the "audio", so I checked the appropriate box, logged out, logged in again, and I had fixed the problem.
    I've had it happen with distros other than ubuntu. The very first time it happened was years ago, right when I was a total noob, installing Red Hat 7.3 for the first time. I think it's a good rule to have: when you're having problems with audio check permissions (including the audio group) first.
    Aug 2002
    476
    Ok, had to re-install due to a broken filesystem and, off course, it's happening again . Before I start going through the already suggested things here, can anyone tell me, why booting up into Ubuntu 8.04 and then back into mepis brings back sound? It comes and goes randomly in mepis and an Ubuntu-boot, always brings it back.
    Tampa, FL USA
    2,193
    This is what I have to occasionally use on my system:
    sudo killall pulseaudio; sudo alsa force-reload
    Jul 2002
    Vladivostok, Russia
    9,053
    Have you tried rebooting into Mepis only? Possibly it has nothing to do with Ubuntu and only a reboot. Then if Sepero's suggestion works possibly use a startup command to force an alsa load. You could check to see if the alsa modules are loading correctly on boot by the command "lsmod"
  11. #11
    Aug 2002
    476
    JohnT
    I tried that, no difference.
    I just added:
    "options snd-hda-intel model=lg" - to the bottom of: /etc/modprobe.d/alsa-base.
    Now it works every time.
    Thx.
Tags for this Thread
