USB Hub with USB to Ethernet Adapters
Having a problem getting 7 port usb hub to work with usb to ethernet adapters. Any help would be greatly appreciated.
output of dmesg after connecting the USB HUB - LOOKS GOOD
usb 1-4: new high speed USB device using ehci_hcd and address 29
usb 1-4: configuration #1 chosen from 1 choice
hub 1-4:1.0: USB hub found
hub 1-4:1.0: 7 ports detected
usb 1-4: New USB device found, idVendor=1a40, idProduct=0201
usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-4: Product: USB 2.0 Hub [MTT]
tail -f /var/log/messages - LOOKS GOOD
Nov 23 20:22:47 linux-tf9s kernel: usb 1-4: new high speed USB device using ehci_hcd and address 29
Nov 23 20:22:47 linux-tf9s kernel: usb 1-4: configuration #1 chosen from 1 choice
Nov 23 20:22:47 linux-tf9s kernel: hub 1-4:1.0: USB hub found
Nov 23 20:22:47 linux-tf9s kernel: hub 1-4:1.0: 7 ports detected
Nov 23 20:22:47 linux-tf9s kernel: usb 1-4: New USB device found, idVendor=1a40, idProduct=0201
Nov 23 20:22:47 linux-tf9s kernel: usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Nov 23 20:22:47 linux-tf9s kernel: usb 1-4: Product: USB 2.0 Hub [MTT]
output from the /var/log/messages after I connect the usb to ethernet adapter to the usb hub - LOOKS GOOD
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: new full speed USB device using ehci_hcd and address 30
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: configuration #1 chosen from 1 choice
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: New USB device found, idVendor=0fe6, idProduct=8101
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: Product: USB Network Controller
Nov 23 20:24:34 linux-tf9s kernel: usb 1-4.1: SerialNumber:
after I connect another usb to ethernet adapter to usb hub - LOOKS GOOD
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: new full speed USB device using ehci_hcd and address 31
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: configuration #1 chosen from 1 choice
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: New USB device found, idVendor=0fe6, idProduct=8101
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: Product: USB Network Controller
Nov 23 20:26:19 linux-tf9s kernel: usb 1-4.2: SerialNumber:
and another usb to ethernet adapter gets plugged into the hub - LOOKS GOOD
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: new full speed USB device using ehci_hcd and address 32
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: configuration #1 chosen from 1 choice
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: New USB device found, idVendor=0fe6, idProduct=8101
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: Product: USB Network Controller
Nov 23 20:27:16 linux-tf9s kernel: usb 1-4.3: SerialNumber:
OK I think you get the picture now, everything appears to look good from the output. Here is the output of
lsusb
linux-tf9s:/proc # lsusb - LOOKS GOOD
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 046e:5542 Behavior Tech. Computer Corp.
Bus 002 Device 003: ID 045e:0039 Microsoft Corp. IntelliMouse Optical
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 032: ID 0fe6:8101
Bus 001 Device 031: ID 0fe6:8101
Bus 001 Device 030: ID 0fe6:8101
Bus 001 Device 029: ID 1a40:0201 TERMINUS TECHNOLOGY INC.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Finally here is the output of ifconfig -a
linux-tf9s:/proc # ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:A0:C9:E0:FD:ED
inet6 addr: fe80::2a0:c9ff:fee0:fded/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:2520 (2.4 Kb)
eth1 Link encap:Ethernet HWaddr 00:0D:61:254:6A
inet6 addr: fe80::20d:61ff:fe25:d46a/64 Scope:Link
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:2178 (2.1 Kb)
Interrupt:16 Base address:0x6000
eth2 Link encap:Ethernet HWaddr 00:40:F4:5F:F5:53
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:16 Base address:0xa000
eth3 Link encap:Ethernet HWaddr 00:48:54:87:68:38
inet6 addr: fe80::248:54ff:fe87:6838/64 Scope:Link
Interrupt:18 Base address:0xa000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:440 (440.0 b) TX bytes:440 (440.0 b)
BLUETOOTH INTERFACE
pan0 Link encap:Ethernet HWaddr A6:54:32:0E:37:61
THESE TWO INTERFACES ARE FOR MY WIRELESS NIC IN MY LINUX BOX
wlan0 Link encap:Ethernet HWaddr 00:1E:E5:FB:E5:30
inet addr:172.16.2.5 Bcast:172.16.2.255 Mask:255.255.255.0
inet6 addr: fe80::21e:e5ff:fefb:e530/64 Scope:Link
RX packets:5144 errors:0 dropped:0 overruns:0 frame:0
TX packets:5128 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3971991 (3.7 Mb) TX bytes:986163 (963.0 Kb)
wmaster0 Link encap:UNSPEC HWaddr 00-1E-E5-FB-E5-30-35-33-00-00-00-00-00-00-00-00
As you can see there are no usb1 or usb2 or 3 interfaces. Can you shed some light on this. Any help would be greatly appreciated.
I found this link that has some good info but I still have the problem
http://www.linux-usb.org/usbnet/#t-enet
Well, you have 4 ethernet interfaces there, are eth1-eth3 not the USB ethernet interfaces?
Your "ifconfig" will not show what type of connector is present (USB,RJ45 etc) only the interface they are connected to (eth0,pan0,wlan0 etc).
Well problem has been solved. There were a lot of details that I did not include such as what distro and what type of usb to ethernet nics I am using. LOL, I am still trying to find out my self. They are a generic brand that are made in China. Bought them really cheap off of ebay.
Initially I was trying to get this to work in Suse 11.1. I took my usb Hub and the usb to Ethernet adapters to work and had one of our LInux experts troubleshoot it. He said that it worked right away on his machine. Of course I was shocked, comes to find out he was using Suse 11.2.
SInce then, I have installed 11.2 and everything is working as expected. Must be a kernel module that suse 11.2 had that 11.1 did not.
Thanks John T, I was expecting a usb0 or usb1 but later found out it depends on the hardware module on what type of interface will be created for the hardware. Well that was what I was told.
Anyway Thanks
Thanks for you replies.
Greatly appreciated.
