Address of remote network in FreeNX wizard and bit type.
Results 1 to 2 of 2
Thread: Address of remote network in FreeNX wizard and bit type.
    Aug 2002
    476
    Hello Guys,
    Some FreeNX start-up troubles here, need a hand.
    1) I am trying to establish a connection from my workplace PC on my workplaces's LAN to my home PC on my private LAN (LAN-to-LAN). Just typing in the public IP of the target LAN in the "Host" field gets me nowhere, as it fails to connect due to a denial at port 22 SSH - even though I've done the forwarding in my home router and punched the required hole in the local firewall of the target machine.
    This resembles what I'm looking at: http://www.linux-tip.net/cms/content/view/298/26/
    2) My home PC is 64-bit Mepis and my workmachine is a 32-bit Ubuntu. Is this a problem?
    Hope you can assist.
    Aug 2002
    476
    Nobody?
    The message FreeNX comes up with is:
    NX> 203 NXSSH running with pid: 12769
    NX> 285 Enabling check on switch command
    NX> 285 Enabling skip of SSH config files
    NX> 285 Setting the preferred NX options
    ssh: connect to host ["my IP here"] port 22: Connection timed out
