How mount cd player
cd player doesn't play cds. Sys. doesn't see cd player, I think.
Tell us which os you are using.
Is this a new computer or is the cd player new or has just been installed?
You will not see the cd players on most of the distros without media in them.
Install a cd that you know has data on it and when you install it listen and make sure the cd player starts. (you should be able to hear it spin.
How mount cd player
uby 8.04 running old kernel 19 something, I think - so dialup modem will work.
8.04 is broken and can't use apt, etc.
Stuck drive in P4 computer, works (Bought computer for little money from someone who bought faster.)
Cd drive was in 'new' computer. Have kubunt10.04 Lts Desktop cd.
I put cd in drive, drive door closes and light comes on on front of drive.
Nothing on screen.
What do i put in terminal to go further?
Thank you!
How mount cd player
Found this on web & tried:
sudo mount /media/cdrom0/ -o unhide
yielded mount : no medium found.
I can't understand uby documentation re. mount - seems to be no pattern for naming cd drives that I can identify - duh, or something. I've seen sdc, hdc ... .
sudo eject /dev/hdc
yielded can't find or open.
How mount cd player
My earlier answer to this never appeared, so trying again:
uby 8.04 running old kernel - 19 something I think - broken OS, apt won't get : ]
Took my Drive and put it in a 2 gig p4 - thats faster to me - box w/this cd player/rewriter.
Wanted to install Kubuntu 10.04 LTS Desktop from a cd sent for.
CD inserts, llight comes on player, nothing on screen.
Can't find CD player in 'Places' or file sys.- and I don't know what I'm doing...
Thanks.
It means the cd drive is not found or no cd found in drive..
Try the command as root: ls /dev and post the results
Sorry I missed your question, the device listing to mount cd is
/dev/cdrom or /dev/sr0
Your cdrom should be mounted automatically when a cd is inserted. You can double check your distro by manually mounting the cdrom with a cd in it.
jk@jk-desktop:~$ sudo ls /dev
[sudo] password for jk:
536ep0 ptyb7 ptyq6 ptyv5 ram12 tty48 ttyda ttys5 ttyx4
adsp ptyb8 ptyq7 ptyv6 ram13 tty49 ttydb ttys6 ttyx5
agpgart ptyb9 ptyq8 ptyv7 ram14 tty5 ttydc ttys7 ttyx6
audio ptyba ptyq9 ptyv8 ram15 tty50 ttydd ttys8 ttyx7
bus ptybb ptyqa ptyv9 ram2 tty51 ttyde ttys9 ttyx8
cdrom1 ptybc ptyqb ptyva ram3 tty52 ttydf ttysa ttyx9
cdrw1 ptybd ptyqc ptyvb ram4 tty53 ttye0 ttysb ttyxa
console ptybe ptyqd ptyvc ram5 tty54 ttye1 ttysc ttyxb
core ptybf ptyqe ptyvd ram6 tty55 ttye2 ttysd ttyxc
disk ptyc0 ptyqf ptyve ram7 tty56 ttye3 ttyse ttyxd
dsp ptyc1 ptyr0 ptyvf ram8 tty57 ttye4 ttysf ttyxe
dvd1 ptyc2 ptyr1 ptyw0 ram9 tty58 ttye5 ttyt0 ttyxf
dvdrw1 ptyc3 ptyr2 ptyw1 random tty59 ttye6 ttyt1 ttyy0
fd ptyc4 ptyr3 ptyw2 rtc tty6 ttye7 ttyt2 ttyy1
fd0 ptyc5 ptyr4 ptyw3 scd0 tty60 ttye8 ttyt3 ttyy2
fd0u1040 ptyc6 ptyr5 ptyw4 sda tty61 ttye9 ttyt4 ttyy3
fd0u1120 ptyc7 ptyr6 ptyw5 sda1 tty62 ttyea ttyt5 ttyy4
fd0u1440 ptyc8 ptyr7 ptyw6 sda2 tty63 ttyeb ttyt6 ttyy5
fd0u1600 ptyc9 ptyr8 ptyw7 sda3 tty7 ttyec ttyt7 ttyy6
fd0u1680 ptyca ptyr9 ptyw8 sda4 tty8 ttyed ttyt8 ttyy7
fd0u1722 ptycb ptyra ptyw9 sda5 tty9 ttyee ttyt9 ttyy8
fd0u1743 ptycc ptyrb ptywa sda6 ttya0 ttyef ttyta ttyy9
fd0u1760 ptycd ptyrc ptywb sda7 ttya1 ttyp0 ttytb ttyya
fd0u1840 ptyce ptyrd ptywc sequencer ttya2 ttyp1 ttytc ttyyb
fd0u1920 ptycf ptyre ptywd sequencer2 ttya3 ttyp2 ttytd ttyyc
fd0u360 ptyd0 ptyrf ptywe sg0 ttya4 ttyp3 ttyte ttyyd
fd0u720 ptyd1 ptys0 ptywf sg1 ttya5 ttyp4 ttytf ttyye
fd0u800 ptyd2 ptys1 ptyx0 shm ttya6 ttyp5 ttyu0 ttyyf
fd0u820 ptyd3 ptys2 ptyx1 snapshot ttya7 ttyp6 ttyu1 ttyz0
fd0u830 ptyd4 ptys3 ptyx2 snd ttya8 ttyp7 ttyu2 ttyz1
full ptyd5 ptys4 ptyx3 sndstat ttya9 ttyp8 ttyu3 ttyz2
fuse ptyd6 ptys5 ptyx4 sr0 ttyaa ttyp9 ttyu4 ttyz3
hpet ptyd7 ptys6 ptyx5 stderr ttyab ttypa ttyu5 ttyz4
hwrng ptyd8 ptys7 ptyx6 stdin ttyac ttypb ttyu6 ttyz5
initctl ptyd9 ptys8 ptyx7 stdout ttyad ttypc ttyu7 ttyz6
input ptyda ptys9 ptyx8 tty ttyae ttypd ttyu8 ttyz7
kmem ptydb ptysa ptyx9 tty0 ttyaf ttype ttyu9 ttyz8
kmsg ptydc ptysb ptyxa tty1 ttyb0 ttypf ttyua ttyz9
log ptydd ptysc ptyxb tty10 ttyb1 ttyq0 ttyub ttyza
loop0 ptyde ptysd ptyxc tty11 ttyb2 ttyq1 ttyuc ttyzb
lp0 ptydf ptyse ptyxd tty12 ttyb3 ttyq2 ttyud ttyzc
MAKEDEV ptye0 ptysf ptyxe tty13 ttyb4 ttyq3 ttyue ttyzd
mapper ptye1 ptyt0 ptyxf tty14 ttyb5 ttyq4 ttyuf ttyze
mem ptye2 ptyt1 ptyy0 tty15 ttyb6 ttyq5 ttyv0 ttyzf
mixer ptye3 ptyt2 ptyy1 tty16 ttyb7 ttyq6 ttyv1 urandom
net ptye4 ptyt3 ptyy2 tty17 ttyb8 ttyq7 ttyv2 usbdev1.1_ep00
null ptye5 ptyt4 ptyy3 tty18 ttyb9 ttyq8 ttyv3 usbdev1.1_ep81
nvidia0 ptye6 ptyt5 ptyy4 tty19 ttyba ttyq9 ttyv4 usbdev2.1_ep00
nvidiactl ptye7 ptyt6 ptyy5 tty2 ttybb ttyqa ttyv5 usbdev2.1_ep81
oldmem ptye8 ptyt7 ptyy6 tty20 ttybc ttyqb ttyv6 usbdev3.1_ep00
parport0 ptye9 ptyt8 ptyy7 tty21 ttybd ttyqc ttyv7 usbdev3.1_ep81
port ptyea ptyt9 ptyy8 tty22 ttybe ttyqd ttyv8 usbdev4.1_ep00
ppp ptyeb ptyta ptyy9 tty23 ttybf ttyqe ttyv9 usbdev4.1_ep81
psaux ptyec ptytb ptyya tty24 ttyc0 ttyqf ttyva usbdev5.1_ep00
ptmx ptyed ptytc ptyyb tty25 ttyc1 ttyr0 ttyvb usbdev5.1_ep81
pts ptyee ptytd ptyyc tty26 ttyc2 ttyr1 ttyvc vcs
ptya0 ptyef ptyte ptyyd tty27 ttyc3 ttyr2 ttyvd vcs1
ptya1 ptyp0 ptytf ptyye tty28 ttyc4 ttyr3 ttyve vcs2
ptya2 ptyp1 ptyu0 ptyyf tty29 ttyc5 ttyr4 ttyvf vcs3
ptya3 ptyp2 ptyu1 ptyz0 tty3 ttyc6 ttyr5 ttyw0 vcs4
ptya4 ptyp3 ptyu2 ptyz1 tty30 ttyc7 ttyr6 ttyw1 vcs5
ptya5 ptyp4 ptyu3 ptyz2 tty31 ttyc8 ttyr7 ttyw2 vcs6
ptya6 ptyp5 ptyu4 ptyz3 tty32 ttyc9 ttyr8 ttyw3 vcs7
ptya7 ptyp6 ptyu5 ptyz4 tty33 ttyca ttyr9 ttyw4 vcs8
ptya8 ptyp7 ptyu6 ptyz5 tty34 ttycb ttyra ttyw5 vcsa
ptya9 ptyp8 ptyu7 ptyz6 tty35 ttycc ttyrb ttyw6 vcsa1
ptyaa ptyp9 ptyu8 ptyz7 tty36 ttycd ttyrc ttyw7 vcsa2
ptyab ptypa ptyu9 ptyz8 tty37 ttyce ttyrd ttyw8 vcsa3
ptyac ptypb ptyua ptyz9 tty38 ttycf ttyre ttyw9 vcsa4
ptyad ptypc ptyub ptyza tty39 ttyd0 ttyrf ttywa vcsa5
ptyae ptypd ptyuc ptyzb tty4 ttyd1 ttys0 ttywb vcsa6
ptyaf ptype ptyud ptyzc tty40 ttyd2 ttyS0 ttywc vcsa7
ptyb0 ptypf ptyue ptyzd tty41 ttyd3 ttys1 ttywd vcsa8
ptyb1 ptyq0 ptyuf ptyze tty42 ttyd4 ttyS1 ttywe watchdog
ptyb2 ptyq1 ptyv0 ptyzf tty43 ttyd5 ttys2 ttywf xconsole
ptyb3 ptyq2 ptyv1 ram0 tty44 ttyd6 ttyS2 ttyx0 zero
ptyb4 ptyq3 ptyv2 ram1 tty45 ttyd7 ttys3 ttyx1
ptyb5 ptyq4 ptyv3 ram10 tty46 ttyd8 ttyS3 ttyx2
ptyb6 ptyq5 ptyv4 ram11 tty47 ttyd9 ttys4 ttyx3
jk@jk-desktop:~$
Ummm, looks like its showing stuff (players) that aren't there. How do i get rid of all but what's actually on the ide ribbons now? ''' Maybe that would help??
List contents of your /etc/fstab the command would be sudo less /etc/fstab there should be a line near the bottom that looks something like this
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto 0 0
The first part ie. /dev/scd0 is the device, (on my system) the second is the mount point
On a older kernel your devices may be listed as hda, hdb, hdc, or hdd
If you are not running sata or scsi what channel ie. Primary IDE or Secondary IDE on your motherboard is your cd-rom and do you know if your cd-rom is running as Master or Slave?
example: If your jumper on your cd-rom is set to SL and is plugged into your Primary IDE then linux will see it or list it as /dev/hdb.
Once you know how linux see's your cd-rom then you can manually mount it. Lets say your linux see's your cd-rom as /dev/hdb the first thing you need to do is pick or make a mount point.
sudo mkdir /mnt/mountpoint
next mount the dev.
sudo mount /dev/hdb /mnt/mountpoint
now you should be able to cd (change directory) to that directory and view the contents of the cd or use a file manager on the gui side to view contents.
note: to unmount the drive when your done make sure you are not in the directory then give the command
sudo umount /dev/hdb /mnt/mountpoint
Let us know if this works.
Are you trying to install 10.04 with Ubuntu 8 running?
Reason: add info
How cd player
Thank you very much for your reply, I think I'll be able to do something with that (in other words I think I understand parts...).
If get it going would like to boot into 10.04 cd & install it w/8.04 off.
Of course, i don't know how to install to my home thingy but I'm hoping to make some sense out of it as I go along... .
CD drive is cable select master on secondary IDE.
Will attempt your above when I can get back.
Mon, Tues., maybe Wed., I hope.
Discretionary time gone until then, or maybe beyond. : [ Thanks again!
After answering this again next week should I start a fresh thread if I have any additional questions so I don't get buried?
Phantom Cd Machine
Thanks 4 your reply -
... sudo less /etc/fstab[/B] there should be a line near the bottom that looks something like this
THIS is what mine says:
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec,utf8 0 0
SO: Secondary ide master should b /dev/hdc ???
And given scd0, that doesn't make sense to me - secondary ide master is the first (0) cd drive? Is that how to read scd0?
Once you know how linux see's your cd-rom - oops - then you can manually mount it. Lets say your linux see's your cd-rom as /dev/hdb the first thing you need to do is pick or make a mount point.
SO: The mount point above 'media/cdrom0' is no good?
next mount the dev.
sudo mount /dev/scd0 /mnt/mountpoint ?
terminal goes to next line w/cursor at first space... I waited -
then put in password again, hit enter, ... and waited...
Tried sudo mount /dev/scd0 /mnt/mountpoint in another terminal - same thing. Ah, eventually said: jk@jk-desktop:~$ mount: No medium found
Um, fstab lists old cd player that is not there now? Or what???
Gee, and I thought you had me all figured out and I was going to live happily ever after... : )
Your cd is probably not listed as /dev/hdb.
You need to run command
sudo less /etc/fstab and post the results
You should be able to mount your cd
sudo mount /dev/cdrom /mnt/mountpoint
sudo less /etc/fstab:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
UUID=cb0b155e-842e-411e-aa32-fff713777d0c / ext3 relatime,errors=remount-ro 0 1
# /dev/sda4
UUID=ffeb82e8-8f01-40d5-bd39-5e204009ac97 /home ext3 relatime 0 2
# /dev/sda6
UUID=8a34ae78-5db8-4de5-9e1c-863e01b36ea4 /usr ext3 relatime 0 2
# /dev/sda7
UUID=dfdda4b9-b6cf-4d1a-9919-797b239fa299 /var ext3 relatime 0 2
# /dev/sda5
UUID=4999-A130 /windows vfat utf8,umask=007,gid=46 0 1
# /dev/sda3
UUID=974aa8ac-5aeb-4fd5-9c20-453d85302d45 none swap sw 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
(End)
/dev/scd0 line waa posted above. According to an above previous post media/cdrom is a mount point. I can't get a handle on this -partly- because I can't make sense out of it. Can't remember nonsense. Please spell it out for me.
