Hi
I have an issue with one of my disks.
I recently installed Mint on my desktop and the internal drive in question is an 8TB
I have the ntfs-3g installed and it is able to see my other drives, I have like 4 other drives and it sees them all and I can go through them, I just cant access 1 of them
I get an error that states Unable to "Mount Location - Cant Mount File"
Can someone point me in the right direction here?
When I do a mount command it shows loads of stuff I dont really get...
The drive I am having an issue with is called Media
Also I should mention that this is a dual boot system and the Windows system has no issue reading all the files etc on the drive.
Mount output
~$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=16350032k,nr_inodes=4087508,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=3278208k,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/sdd2 on / type ext4 (rw,relatime,errors=remount-ro)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14053)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
/var/lib/snapd/snaps/hello-world_29.snap on /snap/hello-world/29 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/bare_5.snap on /snap/bare/5 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/core20_2501.snap on /snap/core20/2501 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/snap-store_1270.snap on /snap/snap-store/1270 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/gtk-common-themes_1535.snap on /snap/gtk-common-themes/1535 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/mailspring_549.snap on /snap/mailspring/549 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/gnome-42-2204_202.snap on /snap/gnome-42-2204/202 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/core22_1908.snap on /snap/core22/1908 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/core_17200.snap on /snap/core/17200 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/snapd_23771.snap on /snap/snapd/23771 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/core18_2855.snap on /snap/core18/2855 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/taskade_38.snap on /snap/taskade/38 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/var/lib/snapd/snaps/gnome-3-28-1804_198.snap on /snap/gnome-3-28-1804/198 type squashfs (ro,nodev,relatime,errors=continue,threads=single,x-gdu.hide,x-gvfs-hide)
/dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sda2 on /mnt/media type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3278204k,nr_inodes=819551,mode=700,uid=1000,gid=1000,inode64)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sdf1 on /media/wayne/YOUTUBE type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
The sudo parted output :
~$ sudo parted -l
Model: ATA ST8000DX001-3GK1 (scsi)
Disk /dev/sda: 8002GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17.4kB 16.8MB 16.8MB Microsoft reserved partition msftres
2 16.8MB 8002GB 8002GB ntfs Basic data partition msftdata
Model: ATA WDC WD4005FZBX-0 (scsi)
Disk /dev/sdb: 4001GB
Disk Flags:
*** buffer overflow detected ***: terminated
Aborted
Not sure if this is helpful or not... sudo fdisk -l output below
~$ sudo fdisk -l
Disk /dev/loop0: 104.19 MiB, 109252608 bytes, 213384 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop2: 63.75 MiB, 66850816 bytes, 130568 sectors
Disk /dev/loop3: 55.36 MiB, 58052608 bytes, 113384 sectors
Disk /dev/loop4: 73.89 MiB, 77475840 bytes, 151320 sectors
Disk /dev/loop5: 164.82 MiB, 172830720 bytes, 337560 sectors
Disk /dev/loop6: 516.01 MiB, 541073408 bytes, 1056784 sectors
Disk /dev/loop7: 91.69 MiB, 96141312 bytes, 187776 sectors
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 970 EVO Plus 1TB
Disklabel type: gpt
Disk identifier: 0F4D55E2-5DF4-4B58-A74E-75FA5958E99A
Device              Start        End    Sectors   Size Type
/dev/nvme0n1p1       2048     206847     204800   100M EFI System
/dev/nvme0n1p2     206848     239615      32768    16M Microsoft reserved
/dev/nvme0n1p3     239616 1952073727 1951834112 930.7G Microsoft basic data
/dev/nvme0n1p4 1952073728 1953521663    1447936   707M Windows recovery environment
Disk /dev/sda: 7.28 TiB, 8001563222016 bytes, 15628053168 sectors
Disk model: ST8000DX001-3GK1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 821CF1DB-420F-478C-935B-CBC173B9582E
/dev/sda1     34       32767       32734   16M Microsoft reserved
/dev/sda2  32768 15628050431 15628017664  7.3T Microsoft basic data
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: WDC WD4005FZBX-0
Disklabel type: gpt
Disk identifier: 62B958B8-17D5-4892-9FF2-086562D3A264
/dev/sdb1     34      32767      32734   16M Microsoft reserved
/dev/sdb2  48195 7814034498 7813986304  3.6T Microsoft basic data
Partition 2 does not start on physical sector boundary.
Disk /dev/sdc: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: Samsung SSD 870
Disklabel type: gpt
Disk identifier: FD9127EE-23ED-40A9-8BA9-27551F5C6701
/dev/sdc1     34      32767      32734   16M Microsoft reserved
/dev/sdc2  32768 7814033407 7814000640  3.6T Microsoft basic data
Disk /dev/sdd: 2.73 TiB, 3000592982016 bytes, 5860533168 sectors
Disk model: Hitachi HDS72303
Disklabel type: gpt
Disk identifier: 4B36268D-07F5-4689-924F-D1B1D7603303
/dev/sdd1     2048    1050623    1048576  512M EFI System
/dev/sdd2  1050624 5860532223 5859481600  2.7T Linux filesystem
Disk /dev/sde: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: ST4000DM000-2AE1
Disklabel type: gpt
Disk identifier: 2BC05F0F-7F65-4BF1-88C9-12E61F2C2CB3
/dev/sde1   2048 7814033407 7814031360  3.6T Microsoft basic data
Disk /dev/sdf: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: STACK 1TB HDD
Disklabel type: gpt
Disk identifier: 1820B039-612A-42DF-911B-2D272316794A
/dev/sdf1   2048 1953525134 1953523087 931.5G Microsoft basic data
Disk /dev/loop8: 20 KiB, 20480 bytes, 40 sectors
Disk /dev/loop9: 171.19 MiB, 179503104 bytes, 350592 sectors
Disk /dev/loop10: 44.45 MiB, 46604288 bytes, 91024 sectors
Disk /dev/loop11: 90.46 MiB, 94851072 bytes, 185256 sectors
Disk /dev/loop12: 10.83 MiB, 11354112 bytes, 22176 sectors
/tia
