Sound Card probs...
Okay, I am running RH 7.0 and I can't get my sound card to work. Maybe someone can tell me what I am doing wrong? Here goes...
I bring up a terminal as root and run sndconfig. It gives the message:WARNING: DISPLAY is set. It is recommended that sndconfig *not* be run from X Windows. Continue anyways? I click YES.
On the PNP Probe Results: A PnP sound card was found in your system. The details are: Model: ESS ES1868 Plug and Play Audio Drive. I click Ok.
Next I get a File Exists message: There is a file called /etc/isapnp.conf. The existing file will be renamed /etc/isapnp.conf.bak and a new file will be written. I click Ok.
I get another File Exists message: There is already a file called /etc/modules.conf. The existing file will be renamed /etc/modules.conf.bak. and a new file will be written. I click Ok.
On the Sound Card Test screen: A sound sample will now be played to determine if your sound card is correctly configured. I click Ok.
I hear nothing...
And the isapnp error screen: The following error occured while running the isapnp program: Don't know what to do with INT 0 (IRQ 5 (MODE +E))) on or around line 60 /etc/isapnp.conf:60 -- Fatal - Error occured parsing config file --- no action taken. I click Ok and it brings up the manual configuration which also doesn't work.
Any suggestions would be appreciated...even if its "Buy a new card dumbass." Thanks...
Maybe this will help.
Otherwise, I'd buy a newer card (preferably PCI).
Marge: Well I think we should spend the money on something the whole town can be proud of.
Homer: Like a giant billboard that says "No Fat Chicks"?
The Simpsons - 9F10 - S04E12
Marge vs. the Monorail
Thanks much, I didn't try searching for anything because I didn't think that there would be anything there considering the card..
Sound Card Distro
Sup, I use 2 hav a similar prob wid me sound card (Asound Gold ISA). Mandrake 8.1 neva use 2 pick it up correctly. Neways, when me upgraded 2 Mandrake 8.2 , my sound card was semi detected. It works n stuff but... ne lil mistake i make n it stops playin ie. when i probe da system. Neway, doesnt affect me 2 much. Me modem is interferring wid da sound neways when im online. Me is plannin on building up a pc n runnin it as proxy/firewall. When i get da job done... it mite as well also run as me hifi Btw ppl, me is upgradin 2 slack neways... so no flame mail plz
The 12th commandment.... "rm -f /mnt/windows"
